building a 402
Donny vestal
427s have a 4.25 inch bore, 402s are 4.125. Boring a 402 .125 would make some thin cylinder walls. You could get a 454 block and put your crank in it with new pistons, but at that point why not go 454? The extra .250 inch stroke would help torque. There are some stroker pistons out there, a 454 crank in your 402 would get you 433 with a .030 over bore. Seems like lots of cost when there are still 454s to be found.
