Charlie72 Posted June 13, 2001 Share Posted June 13, 2001 Well i'm am near finish rebuilding the engine 350ci. Stainless? Ceramic coated? anyone company? I have the stock exhaust manifolds ready to go back on and then I thought...what if.!?! I plan on running duals with the H crossover. So I'm just lookin for ideas. Link to comment Share on other sites More sharing options...
Andreas Posted June 13, 2001 Share Posted June 13, 2001 Regular Flowtech Headers, part no. 11108FLT will fit pretty nice (unless you have manual tranny). You will need a custom bracket for the A/C. These headers are available with black paint (which burns off within two minutes) or ceramic coated. Link: http://www.holley.com/HiOctn/ProdLine/Products/ES/ESFT/FThdr.html ------------------ 71 Monte 383 "The Full Monty" 86 Monte LS ZZ4 "The Gray Mouse" Andreas' Monte Carlo Site Member NMCOA, FGMCC (Event Coordinator) --------------------------------------- "It ain't a car if it's not a Monte" Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2001 Share Posted June 13, 2001 I went with Dynomax ceramic coated headers for $199. They installed just fine. Check out the picture below. http://albums.photopoint.com/j/ViewPhoto?u=1414705&a=10577914&p=47541472&f=0 Lon Link to comment Share on other sites More sharing options...
Guest Posted June 13, 2001 Share Posted June 13, 2001 When you bring the picture I just posted up, you can make it even larger by clicking on it again. This will give you a clearer image of the headers and the ceramic coating. This is on my Monte. Lon Link to comment Share on other sites More sharing options...
superstk Posted June 13, 2001 Share Posted June 13, 2001 Word of caution in regards to ceramic coated headers. This coating should last a long time but as I found out with a set of Hooker Super Comp Headers it doesn't. When they coat the headers, after coating they tumble them to polish the coating so it looks shiney. But, what happens is that this also removes some of the coating and makes it thinner. Hot headers + a little moisture = RUST. I know of a company that coates headers in Chicago if your intrested. They prefer untreated headers to coat. I just recoated mine again with a dark grey coating that they guaranty for life. If it peels or rusts they will redo them for free. As I see it now only time will tell. Link to comment Share on other sites More sharing options...
Guest Posted June 14, 2001 Share Posted June 14, 2001 Check these headers out that are on my 396. I had them done by Jet Hot last fall and they guarantee them for life against rust. They stripped them down to bear metal before coating them. Lon http://albums.photopoint.com/j/View?u=14...=0&res=high ------------------ Link to comment Share on other sites More sharing options...
iceman Posted June 14, 2001 Share Posted June 14, 2001 I used Heddman shortys on my BB. They fit well. I just got new ones to get rid of the AIR tubes and sent them to Jet-Hot. I have never heard of any problems with their coatings unless the headers that were sent were rusted to start with. I would stay away from full length headers to keep your ground clearance. When I had the SB in the car I would drag over speed bumps with the full length headers. My shortys don't even come close to touching even with the front end sitting a little lower than stock. [This message has been edited by iceman (edited 06-13-2001).] Link to comment Share on other sites More sharing options...
superstk Posted June 14, 2001 Share Posted June 14, 2001 I had that problem (scrapping) but corrected that with a set of stiffer front springs. Never happened again. Link to comment Share on other sites More sharing options...
Guest Posted June 15, 2001 Share Posted June 15, 2001 Ya, I have big block springs in my Monte (see picture above) and I NEVER hit/rub on anything. You can see by the picture I have plenty of clearance. Just an option for ya. Lon Link to comment Share on other sites More sharing options...
