ENGINE - Fan Shroud removal - possible w/out removing fan?
Is it possible to remove the fan shroud without also having to remove the fan? If so, how? (Note: Small Block engine)
Thanks,
Allen
never done it personally, but if you look closely you see that the shroud is maybe in 2 pieces, and on the left n right centre are staples thru the plastic, leastways thats how it looks to me. but i know what you mean, i was trying to get to the harmonic balancer, and realised it was not 1 man job to take out and relocate fan unit n shroud etc, tho someone told me to replace fan bolts with studs n nuts, good idea methinks, but i didnt complete the job anywayz, another day smile.gif
jon
Looking at it again I can see three ways of getting the shroud off (Sawsall method not included):
1. Pull radiator after removing shroud and sitting it over the fan.
2. Remove fan
3. Remove staples holding shroud together.
I think I like option 1 or 2 for right now.
Thanks,
After taking it loose just pull it back over the fan blade, turn it. I forget right or left, then you can work it out without messing anything up. David
Holly Smokes! What is involved in taking off the fan? Four fasteners? Whew!
