Guest Posted November 11, 2003 Share Posted November 11, 2003 is there a way to adjust the column shifter for gear changes???? Quote Link to comment Share on other sites More sharing options...
Guest Posted November 11, 2003 Share Posted November 11, 2003 Yes! Oh I suppose I should explain. Down below the car there is a rod that goes into the U shaped bracket. Loosen the I think 7/16 bolt and re-position to your lik'in ------------------ <IMG SRC=\"http://... LLOYD@firstgenmc.com Quote Link to comment Share on other sites More sharing options...
montefrazer Posted November 12, 2003 Share Posted November 12, 2003 Also check for worn stuff while you're down there. There is a plastic bushing that can wear or disappear. This will allow the linkage to move around but not shift the trans right. ------------------ Steve Quote Link to comment Share on other sites More sharing options...
kc8oye Posted December 3, 2003 Share Posted December 3, 2003 That explains a great many things... the fact that I can move teh shifter up and down about 3-4" before I come out of 3rd? and that reverse is a !@#%$#$ to find sometimes? Also check for worn stuff while you're down there. There is a plastic bushing that can wear or disappear. This will allow the linkage to move around but not shift the trans right. Quote Link to comment Share on other sites More sharing options...
