Deni2nd Posted February 25, 2018 Share Posted February 25, 2018 Has anyone used the Procar bucket seats before Interested in feedback here. They look to be a nice alternative for the resto mod conversion Quote Link to comment Share on other sites More sharing options...
cbolt Posted February 26, 2018 Share Posted February 26, 2018 I used the SCAT 90's in my ford. They are very nice indeed. Quite comfortable Quote Link to comment Share on other sites More sharing options...
keith72monte Posted February 27, 2018 Share Posted February 27, 2018 I have the procar scat seats. They aren't as comfortable as the factory seats. Not a lot of padding for long drives. If your a skinny person,(I am not) then they will be more comfortable. I also have to get out of the seat to slide it forward. if your under 225 pounds, then they should slide forward and back without having to get out of the seat.They have a upward angle in the front, that's ok when your close to the steering wheel , as you would be for racing. I put bath towels on the bottom , helps from cutting into the back of my legs on three hour drives to the beach, also keeps the seats clean once I get to the show.Fabric on those seats aren't easy to clean , don't spoil mustard or anything like that, doubt it would clean up . If your racing on a track, then they are better then stock seats. If your just cruising around to local shows or whatever, Your going to be better with factory seats. If you decide to go with racing seats and 5 point belts, you have to be careful, shoulder belts for racing are meant for cars with roll bars in them. Incase you roll the car, factory belts allow your body to slide downward. 5 points will hold you upright and roof will come down on your head.They make shoulder seat belts for street car, schroth brand , used in b&w,s road racing .they are pricey ,if you go with the electronic sensor mechanism. that allows for free movement when you want lean to go forward in seat without having to loosen belts, but meant to be used for a street car. For a cruiser to the car shows and doing some burn outs, just go with factory. I did it for the cost. Find a nice used set oem seats for around 400 and recover them. Plus now they have oem style covers with side support. They came out with that right after I had installed mine. If I only had one monte carlo, I would take the seats out. I bought oem style bucket seat brackets to weld in the floor, but the scat seat rails wouldn't line up and had to weld in the brackets differently.. my car was a bench seat, I bought the complete kit they sold, and also the oem style brackets from goodmark.. Maybe someone else with oem brackets can say there scat bolted right up to oem brackets? Look at the guys monte,s on here,with high horsepowered cars with different options then procar seats. new forum topic.. What seats do you have in your monte and do you race it on the track. I just seen a touring series by pro car that looks a lot more padded and side support .but no spots for 5 harness. There is my input on scat procar seats. Quote Link to comment Share on other sites More sharing options...
cbolt Posted February 28, 2018 Share Posted February 28, 2018 I find them comfortable for long trips, but I was able to use the procar mounting brackets with no modification to the bracket. Perhaps that is the difference? Quote Link to comment Share on other sites More sharing options...
keith72monte Posted February 28, 2018 Share Posted February 28, 2018 Cbolt, you didn't have to weld in brackets, because yours had factory buckets? the base for the procar bolted right onto the oem bucket seat mounts? no welding needed? things were not lining up for me. my good luck as always. Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 1, 2018 Share Posted March 1, 2018 Yes, mine bolted right in, but I used procar seat mounting brackets. They make seat mounting brackets for a variety of applications, and I found a set that bolted into the factory floorboard mounting holes. Â Bear in mind the procar seats are in my ford, not my monte carlo. I would think, but cannot verify, procar makes brackets for our cars. Quote Link to comment Share on other sites More sharing options...
monte70car Posted March 1, 2018 Share Posted March 1, 2018 To speak on behalf of Keith he did receive the mounting bracket for the seat when he ordered. He was changing over from bench to buckets so he brought the factory style bucket seat mounts that welded to the floor. The mounting brackets for the Procar seat would not allow the seat to mount in the stock location and if the seat was in the stock location it make the seat look twisted in the car. We (me and my late father) made it so the seat looked squared in the car by changing the floor broad mounting bracket. Now if you have the right round stock on hand you probably could cut the mounting tabs for the seat off and length the mounting bracket for the seat. Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 2, 2018 Share Posted March 2, 2018 They make a universal mounting bracket as well. If yours didn't fit correctly you could have tried the universal bracket. Regardless, I enjoy my procar seats, but I had no issues with fit during installation. Quote Link to comment Share on other sites More sharing options...
502ci Posted March 2, 2018 Share Posted March 2, 2018 I put ProCar seats in mine to replace my bench seat. Been quite a few years but they mounted right up from what I remember...maybe I ordered the universal brackets, I just don't remember. I am using my phone so I can't reference the exact seat I bought but it is the sportier type with side bolsters. My driver seat always seemed tighter in the thigh area than my passenger seat. I figured it would loosen up as that seat would get the most use...not so, pretty much as stiff as the day I put it in, lol. Quote Link to comment Share on other sites More sharing options...
502ci Posted March 2, 2018 Share Posted March 2, 2018 Here's the seat I have... https://www.summitracing.com/parts/sca-80-1000-51r  Like I mentioned it kinda feels tight on the thighs after about a half hour of driving but I can live with it. I will say these are secure seats for your body, they will hold you in place.  Quote Link to comment Share on other sites More sharing options...
keith72monte Posted March 3, 2018 Share Posted March 3, 2018 i bought the kit for 68 to 72 a body. maybe a universal base might work. the scat seats I bought had the 5 way slots, not like the touring model picture above.Much more padding on the ones Bill has. I will get a part number and ad to topic. Quote Link to comment Share on other sites More sharing options...
Deni2nd Posted March 3, 2018 Author Share Posted March 3, 2018 So at this point all I have bought is the seats. It is a conversion from bench to buckets. I am not skinny 260 lbs I still need the mounting hardware and seat adjusting tracks. A bit confused from the comments. Can someone post a link to the best option. Quote Link to comment Share on other sites More sharing options...
keith72monte Posted March 3, 2018 Share Posted March 3, 2018 this is what I bought in 2012, theres a lot more to offer now. Maybe I was sent the wrong base brackets? the sliders have three slots in front and back for height adjustments. if you want gm style oem brackets for conversion, then get some from ebay through goodmark, or any supplier. they have to be welded in. maybe some guys on here have pictures of there factory bucket cars, showing the correct bracket? Just order what procar says to install and see if it works, since you have the seats already.If things don't line up, just send it back and go with a different company. If things don't line up , have them email or mail you a return label, soo you don't have to pay return shipping. Not your fault they sold you the wrong item. Quote Link to comment Share on other sites More sharing options...
keith72monte Posted March 4, 2018 Share Posted March 4, 2018 hey Donald, here are the brackets you have to get. Ask any questions, We are here to help. Quote Link to comment Share on other sites More sharing options...
502ci Posted March 4, 2018 Share Posted March 4, 2018 hey Donald, here are the brackets you have to get. Ask any questions, We are here to help.     Seeing those pictures gave me a flashback, I kinda remember putting a shim (1/4') square washer on one side of each seat to make them perfectly level with the car. You may not have to but even with a universal kit sometimes you have to improvise. Quote Link to comment Share on other sites More sharing options...
cbolt Posted March 5, 2018 Share Posted March 5, 2018 I have a set of universal brackets im not using if anyone wants them. They fit the procar seats. Quote Link to comment Share on other sites More sharing options...
Deni2nd Posted April 26, 2018 Author Share Posted April 26, 2018 Keith What did you use for adjustable tracks? I will need to slide the seat forward and back so both my wife and I can drive Quote Link to comment Share on other sites More sharing options...
