70 Iron Posted December 3, 2007 Share Posted December 3, 2007 I changed my 2 barrel manifold to a 4 barrel with a Alumimun performer.I went with a stage 2 Quadrajet from Jegs.Do they make a differnt cable for the 4 barrel kickdown ?My kickdown cable is 2 inches or so short. The engine is a 350.I put a new throttle cable on for the 4 barrel which works fine. I was wondering if any of you went thru this and what you did to correct it.Thanks Terry Quote Link to comment Share on other sites More sharing options...
Guest 72yellowmc Posted December 3, 2007 Share Posted December 3, 2007 I went from a 2 barrell to a 4 barrel with no problem.... still have the same set up. Quote Link to comment Share on other sites More sharing options...
70 Iron Posted December 3, 2007 Author Share Posted December 3, 2007 I used the same bracket that was on the cable originly,and bolted it in the same back left two bolts.Maybe the carb linkage is the problem.I'll look a little closer tomorrow ,it was kind of late when I finished and also a little tired,I'm getting to old to tackle jobs like this!! lol Thanks 72 Terry Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted December 3, 2007 Share Posted December 3, 2007 I went to a 4 bbl, I needed a different bracket to hold the kickdown linkage, I got it from edelbrock, and it needed modification anyway. I used the same cable from the 2 bbl though Quote Link to comment Share on other sites More sharing options...
70 Iron Posted December 3, 2007 Author Share Posted December 3, 2007 Thanks Tony, I will look in the Jegs catalog for a bracket.I found the cables in the Paddock cat and they also say that there all the same. Â Tony, I sent you a PM. Terry Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted December 3, 2007 Share Posted December 3, 2007 Terry, I found my reciept from Jegs, the extras I ordered were part # 03508012... Throt/AT Cable ext.kit chevy ($5.99) part # 03508031... Throttle Bracket Universal ($24.99) Its been a while since I did this, but now I do remember the throttle bracket not working from my original, and the new one needed minor modification, and as far as I know, I never used the extention kit for the kickdown cable. Hope this helps you out. Got your PM and you got 2 back! Quote Link to comment Share on other sites More sharing options...
alex's72fgmc Posted December 3, 2007 Share Posted December 3, 2007 i had the same issue with billies car i had to use a universal kickdown bracket as i went to a squarebore carb "edelbrock 1407" and the kickdown pin was further forward. causing an issue with install of the kickdown cable i had to hack a spare aftermarket kickdown bracket to make the kickdown cable to work. Â Alex Quote Link to comment Share on other sites More sharing options...
70 Iron Posted December 4, 2007 Author Share Posted December 4, 2007 I fixed the kickdown problem today, It was'nt as short as previously thought,it was about 1 1/2".I extended the slot in the kickdown with a "slot" from a newer model cruise control and just cut off the rod part,used a small bolt and double nut to lock it where the adjustment should be,and hooked the other end on the stud on the carb. This will work until I find the original bracket.I just took it out for a spin and it all worked great.The new rear gears 308:1 {had 256:1}the dual exhaust and the 4 barrel sure made a difference. Thanks to all Terry Quote Link to comment Share on other sites More sharing options...
70 Iron Posted December 4, 2007 Author Share Posted December 4, 2007 Tony!! I forgot to thank you for digging out your # and receipts.I will make a copy just in case its needed later. Terry Quote Link to comment Share on other sites More sharing options...
