Guest SSwolf Posted June 23, 2008 Share Posted June 23, 2008 I am looking to put in a 9" dual power brake booster in my Monte. The car will have a 454. I think the 9" booster fits, but wanted to know if anyone already tried this. Also I am hoping that this booster with a 1 1/8 bore master cylinder will work well with 4 wheel disk brakes. Two piston 98-02 camaro calipers and single piston rear calipers from the camaro as well. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted June 23, 2008 Share Posted June 23, 2008 If you are going to go that far, there are many companies making complete matched kits that would make the switch a breeze Quote Link to comment Share on other sites More sharing options...
Heckeng Posted June 23, 2008 Share Posted June 23, 2008 You should be fine with that combo I would think. You will need a new proportioning valve though. The stock ones have a residual pressure valve for the rear drum brakes that will cause your rear disk brakes to stick. Quote Link to comment Share on other sites More sharing options...
