Mikstudie Posted March 4, 2022 Share Posted March 4, 2022 I have dual cooling fans, started the car last weekend and fans are not cycling. Had them in the car for years never a issue. Where would you guys start with diagnosis. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted March 4, 2022 Share Posted March 4, 2022 Many things to consider. Are they controlled by a thermostat or are they supposed to come on and stay on as soon as the key is turned on? Is there a relay in the system? Are they fuse protected? Is there a fusable link someplace in the wire? I suspect since both of them are not working the chances of them both going bad at the same time would be unlikely so I suspect the power to them has been interrupted. Rob 1 Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted March 7, 2022 Author Share Posted March 7, 2022 Rob, I pulled the relay is wasn't dirty but I wiped it off anyway. Started the car and fans working perfect. Yes it does have a fuse link. Fans are energized by temp sender in thermostat housing/goose neck. Ill let you know when I start it again next weekend. Quote Link to comment Share on other sites More sharing options...
