electric cooling fans
Mikstudie
I have dual cooling fans, started the car last weekend and fans are not cycling. Had them in the car for years never a issue.  Where would you guys start with diagnosis.
Many things to consider.
Are they controlled by a thermostat or are they supposed to come on and stay on as soon as the key is turned on?
Is there a relay in the system?
Are they fuse protected?
Is there a fusable link someplace in the wire?
I suspect since both of them are not working the chances of them both going bad at the same time would be unlikely so I suspect the power to them has been interrupted.
Rob
Rob, I pulled the relay is wasn't dirty but I wiped it off anyway. Started the car and fans  working perfect. Yes it does have a fuse link. Fans are energized by temp sender in thermostat housing/goose neck. Ill let you know when I start it again next weekend.
