FrankOC Posted July 4, 2023 Share Posted July 4, 2023 After the monsoon in Carlisle I found the passenger side carpet was damp. I have the inner fender out and there are two smaller gaps in the seam sealer and the fan had little sealant around it. Also, I didn’t drive the car so the rain entered while the car was sitting still. Any known leak areas I should be looking at? Thanks Quote Link to comment Share on other sites More sharing options...
jft69z Posted July 4, 2023 Share Posted July 4, 2023 Most of the water would typically go into the cowl itself & drain out the bottom. Best bet may be to take a hose to the cowl area and see what happens. I'll give you a call, may be easier. 1 Quote Link to comment Share on other sites More sharing options...
FrankOC Posted July 4, 2023 Author Share Posted July 4, 2023 Thanks for the assists, Joe and CK. I had a leak on the front side of the kick panel vent at the firewall so I will reseal that and look for any others. 3 1 Quote Link to comment Share on other sites More sharing options...
