This can’t be good.
John S
Was going to pull the tailstock and remove and replace the reverse shifter shaft seal. But as the picture shows the reverse cam boss taper pin is installed upside down. It should go from top to bottom not bottom to top. That is a problem. I decided to read up on that and found it could cause a lot of problems Might just have to leave it alone. Don’t know if I want to open up a big can of worms. You can see by the pictures.
10 minutes ago, Marks71 said:
Between that and the bearing retainer nut, makes you wonder what else might be wrong.
Had the car for 10 years. Transmission drives shifts well and is very quiet. Never had any issues. Just had to change a couple leaking seals and gaskets.
For those reasons i would leave it alone
