ejw71 Posted February 26, 2006 Share Posted February 26, 2006 My Th350 has a switch with a two wire hook up. Is this for back up lights? Thanks, Ed Quote Link to comment Share on other sites More sharing options...
ejw71 Posted March 3, 2006 Author Share Posted March 3, 2006 Calling on member(s) to answer above question. Thanks, Ed Quote Link to comment Share on other sites More sharing options...
montefrazer Posted March 3, 2006 Share Posted March 3, 2006 Where is the switch located and do you know what year the tranny is? Different years had switches for different things. Probably won't be back up lights. That switch is usually on the lower part of the column with the neutral safety switch. Quote Link to comment Share on other sites More sharing options...
ejw71 Posted March 3, 2006 Author Share Posted March 3, 2006 Steve, Another dumbo moment, don't know why I didn't include the year. It's a '71 TH350. Switch is located on passenger side to left of TV cable and below transmission lines. Somethng just click in my head. Suspect it's involved with the igintion timing, like retaring it. Thanks for the help. Ed Quote Link to comment Share on other sites More sharing options...
Mr70Monte Posted March 3, 2006 Share Posted March 3, 2006 its the switch for the TCS (transmission controlled spark) it controls the soleniod between the carburator & the distributor. basically it turns the vacuum on or off depending on what gear the transmission is in. it allows vacuum to the distributor in high gear & reverse. Quote Link to comment Share on other sites More sharing options...
ejw71 Posted March 3, 2006 Author Share Posted March 3, 2006 Thanks MR70Monte, That's it. Now remember asking this question before. Yep, the first parts to go are brain cells. Ed Quote Link to comment Share on other sites More sharing options...
montefrazer Posted March 4, 2006 Share Posted March 4, 2006 Yep, the first parts to go are brain cells. Ed Only the weak ones and who wants them? Quote Link to comment Share on other sites More sharing options...
