Guest Posted July 27, 2003 Share Posted July 27, 2003 i had to remove the clutch linkage to install my headers today, and when i put it all back together, the clutch wont engage, the pedal is extremely firm, and the pedal sits a lot higher. i think i put it back together wrong. does anyone have a picture or a diagram of what it is supposed to look like? Quote Link to comment Share on other sites More sharing options...
wallaby Posted July 27, 2003 Share Posted July 27, 2003 Is it possible that the Z-bar needs to be turned around? I mean, could it be that the end of the bar that should be against the frame got put against the transmission? Quote Link to comment Share on other sites More sharing options...
Guest Posted July 27, 2003 Share Posted July 27, 2003 Did your clutch fork slip off the swivel ball or is not located on the ball properly? Quote Link to comment Share on other sites More sharing options...
Guest Posted July 27, 2003 Share Posted July 27, 2003 the clutch fork is fine. that didnt move and everything seems like it is where it should be, but it still aint workin. i really need to see a diagram or picture of what it is supposed to look like. Quote Link to comment Share on other sites More sharing options...
montefrazer Posted July 28, 2003 Share Posted July 28, 2003 If everything went right, you have mail. ------------------ Steve Quote Link to comment Share on other sites More sharing options...
montefrazer Posted July 28, 2003 Share Posted July 28, 2003 Your email address doesn't work. If you email me with a good address, I will try again. ------------------ Steve Quote Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2003 Share Posted July 28, 2003 What kind of headers did you install? I have a 454 in my monte and converted it to a 4 speed. I had to remove my Hooker Competition headers because the rod that connects the clutch fork to the "Z" bar. It hit the tube and was no way gonna work. I hate it but I had to put stock manifolds back on. I don't have a picture to send you but good luck......Fran Quote Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2003 Share Posted July 29, 2003 i fixed it. the clutch fork was just out of place a tad. i'm using Dynomax ceramic coated longtubes for 70-81 Camaro big block. fits perfect on the drivers side, i havent put the pass. side on. note that it doesnt list the headers to fit a Monte, but they indeed fit perfectly. they are like 250 or so from Summit Racing. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2003 Share Posted July 29, 2003 Let me know if you don't mind, how you make out with the pass. side. If they fit good I will order a set for mine. Thanks in advance Fran Quote Link to comment Share on other sites More sharing options...
