Guest Posted May 18, 2004 Share Posted May 18, 2004 Last year when I put the engine back in and rebuilt carb, I noticed my tranny would not kick down. The tranny was never removed. It appears to pull on the cable at full throttle, but apparently not far enough. If you twist the little plastic part with the spring that attaches to the intake bracket, will that give/take slack in the cable? Just never got around to messing with it. Thanks. Quote Link to comment Share on other sites More sharing options...
Grease Posted May 19, 2004 Share Posted May 19, 2004 This is from the 1970Chevrolet service manual Detent Cable adjustment for Turbo Hydra-Matic 350 Transmission. 1 Disengage snap lock on detent cable .(located at rear of intake manifold,drivers side) 2 Place caruretor at wide open throttle (W.O.T.)position(make sure throtte lever is against W.O.T. stop).On vehichles equipped with a Qudrajet carburetor disengage the secondary lockout before placing lever in W.O.T. position. NOTE: (Detent cable must be thru detent) 3 With carburetor lever in W.O.T. position snap lock on detent cable downward until top is flush with cable. mike Quote Link to comment Share on other sites More sharing options...
vince Posted May 25, 2004 Share Posted May 25, 2004 Hey PRYO How did the adjustment go on the cable? I am having a similar problem with mine only I can't get the cable clamp to lock on to the support. Was there a clip that holds it in place? Quote Link to comment Share on other sites More sharing options...
Guest Posted May 26, 2004 Share Posted May 26, 2004 Haven't got around to it yet, but the clip I believe is where it snaps into the bracket coming off of the intake. Quote Link to comment Share on other sites More sharing options...
vince Posted May 26, 2004 Share Posted May 26, 2004 oh!! there is a clip! I thought somthing was missing thanks for the info. Quote Link to comment Share on other sites More sharing options...
