MonteFox89 Posted June 18, 2011 Share Posted June 18, 2011 will do, and don't worry man! ONE day you will be able to out build some of the better builders if you just keep at it and do the research. Devotion man, that's all it takes. Quote Link to comment Share on other sites More sharing options...
stangeba Posted June 18, 2011 Share Posted June 18, 2011 Here is a thought, eliminate the mechanical fuel pump and add an electric fuel pump. Tick is gone...... Bruce Quote Link to comment Share on other sites More sharing options...
ddiddle Posted July 1, 2011 Author Share Posted July 1, 2011 That was an option, Bruce...and I seriously considered it, but in the end, I went ahead with the cam replacement. Got it back this week. We went with a slight bump up from an RV, a Comp Magnum 270H. Got everything cleaned and painted, new water pump and fuel pump and plugs and wires, cap and rotor, etc. The best guess is that it was a ZDDP issue. Buy the additive or the oil! You can buy a lot of oil for what this repair cost. I'm still running the Edelbrock 650, but am looking seriously at a quadrajet, as funds allow. Runs great, no noise. Lighter wallet. I also took a deep breath and cut a hole in my "new" dash to fit the rear defogger switch. Came out great. Quote Link to comment Share on other sites More sharing options...
bigtankjones Posted July 2, 2011 Share Posted July 2, 2011 Valvoline VR1 with ZDDP. 6 bucks a quart a O'Reilly's Quote Link to comment Share on other sites More sharing options...
