Kevin Wiles Posted October 20, 2006 Share Posted October 20, 2006 this will work for a 1970 monte carlo, right?? http://www.ss396.com/mm5/merchant.mvc?Sc...ERANDCLUTCHKITS Quote Link to comment Share on other sites More sharing options...
Ian Posted October 20, 2006 Share Posted October 20, 2006 It should, it gives you the extra detent for the 4th gear. Ian Quote Link to comment Share on other sites More sharing options...
Grease Posted October 25, 2006 Share Posted October 25, 2006 Kevin that looks like the correct parts . I have been happy with the setup I put in my car . The kit I used was only the detent and lens . I was able to use the original cable brakets and such. mike Quote Link to comment Share on other sites More sharing options...
Guest Posted October 25, 2006 Share Posted October 25, 2006 i just ordered the Ground Up shifter set monday. can't wait to try it out with my new 700. Quote Link to comment Share on other sites More sharing options...
Kevin Wiles Posted October 25, 2006 Author Share Posted October 25, 2006 after tearing up my th350 for about the third time, I am going to a 700. I'll get better mileage and a better trans (in my opinion) but i've gotta save up to buy one or get lucky and find one cheap. also going to convert my monte to floor shift bucket auto with the kit. i already have the floor gauges, the floor column (tilt!) the console, the seats, all the wiring and linkages. Just need the kit and the trans. with all the hubbub of the coke machine its easy to ignore my other monte's needs. Its especially easy to ignore it because it actually drives fine it just skips 2nd. Which is a miracle that its actually still going as much metal chunks as I removed from the pan in Bristol. Quote Link to comment Share on other sites More sharing options...
Guest Posted October 25, 2006 Share Posted October 25, 2006 i just put a 700R4 in my monte. but right now its at the tranny guys shop getting the final tweeking. im just ITCHING to get her back and test it out. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 8, 2006 Share Posted November 8, 2006 just got my ride back with it's new 700r4 and the shifter kit from the website suggested. it works great, looks stock, and it wasn't a pain to set up. Quote Link to comment Share on other sites More sharing options...
