1970MonteMotion Posted January 20, 2012 Share Posted January 20, 2012 I was unsure of what the carb size was, until I found out, it was an upgrade comp series back in the 1970 from the old Qjet. A little of what I found: Competition replacement for all Quadra-Jet carbs. on 1965-70 327, 350, 402 C.I.D. engs. Mechanical secondaries, spread bore, double pump, 650 c.f.m., non emission, divorced choke The carb works, and operates perfectly fine, but I am wondering if there are better choices for me. I really just want a cruise around town car, that could get up and go if need be. Stock 350/300hp, cam, headers, intake, small stall, shift kit. Nothing fancy. Also, if my carb is a spread bore, does that mean it won't work on square bore intake? Quote Link to comment Share on other sites More sharing options...
monte70car Posted January 21, 2012 Share Posted January 21, 2012 If you look on the choke horn there will be a list of number if you provide that we can take a look and see if it's square bore or spread bore. if its a spread bore then your intake will be spread unless its an after market intake that can take both. Quote Link to comment Share on other sites More sharing options...
overdrive Posted January 21, 2012 Share Posted January 21, 2012 It's in his post: Quote: Competition replacement for all Quadra-Jet carbs. on 1965-70 327, 350, 402 C.I.D. engs. Mechanical secondaries,spread bore, double pump, 650 c.f.m., non emission, divorced choke Robert, (the first one), if you have the original intake, it's a spread bore and your carb fits it with no adapters. Your carb will mount on a square bore intake with an adapter. A spread bore carburetor is a 4 barrel with the primaries (front barrels) small and the secondaries are quite a bit larger. If it's not a spread bore (square bore) then all 4 barrels are the same size. A spread bore is a good choice for a car that runs at lower RPMs alot and will normally give a little better gas mileage. The secondaries are large and will flow alot of air when you firewall the pedal. A carb with vacuum operated secondaries would be more for street than one with mechanical secondaries, but if the one you have works well, all is good. Dan Quote Link to comment Share on other sites More sharing options...
