MGD72Monte Posted January 23, 2012 Share Posted January 23, 2012 I'm about to send out the differential for sandblast, and was wondering about whether I should just tape up the plastic differential vent valve or try to remove it. Is it easy to remove? How do you do it, I don't want to break it. Thanks Quote Link to comment Share on other sites More sharing options...
Slaman Posted January 23, 2012 Share Posted January 23, 2012 I think it is simply pressed in. Probably grab it with pliers and twist back and forth and pull up... Which reminds me I need to replace mine since I snapped it off somehow. that is going to be fun trying to get the reaining pice out. Quote Link to comment Share on other sites More sharing options...
70 Iron Posted January 23, 2012 Share Posted January 23, 2012 Hi Steve, Yes the vent just pulls out,and maybe some easy twisting with pliars.I just tape around mine but I blast my own .The cap also comes off the vent stem by pulling. Terry Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted January 24, 2012 Author Share Posted January 24, 2012 Once it is twisted out, I assume it is re-usable? Do you need a special tool to ?press? it back in? Do you need any kind of sealant as part of the re-install. Thanks Quote Link to comment Share on other sites More sharing options...
70 Iron Posted January 24, 2012 Share Posted January 24, 2012 MG, It just pushes back in with no sealant and no tool.,I've never had any problem with them popping out. Also new ones are available if needed. Terry Quote Link to comment Share on other sites More sharing options...
geartech Posted January 24, 2012 Share Posted January 24, 2012 Yes, they just push back in. They are not expensive new... National Parts Depot part number C_5387_1 $2.81 I have an extra one if you don't want the hassle of ordering, I can throw it in a envelope to you. Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted January 25, 2012 Author Share Posted January 25, 2012 Thanks a lot guys, although a small item, I hate it when I break something because I have no idea how it is supposed to come apart. Thanks for the offer Mike, I'll keep in mind if I damage it. Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted January 30, 2012 Author Share Posted January 30, 2012 To close this off, I ended up removing it and it came out easily twisting it back and forth gently with some vise grips. I also got the cap of by removing it by hand for cleaning. Thanks again. Quote Link to comment Share on other sites More sharing options...
