Charger3488 Posted March 5, 2012 Share Posted March 5, 2012 i have a 502 bbc wat mods can i do besides a shift kit. to better this trans ? Quote Link to comment Share on other sites More sharing options...
Montemedic Posted March 5, 2012 Share Posted March 5, 2012 How will the car be used? Depending on usage, a properly picked/made converter and or a transmission cooler. Changing to synthetic fluid if your trans was recently freshned up or rebuilt. Heat is the number 1 killer of your transmission and drivetrain parts. Proper use of these parts will make car move more efficiently, run cooler and last longer. Quote Link to comment Share on other sites More sharing options...
Charger3488 Posted March 8, 2012 Author Share Posted March 8, 2012 street with a little strip use. But mostly street i kno these trans were put behind ls6 454 bbc and they hhave 450 hp and 500 ilbs of torgue so a little modifications should do the trick thanks Quote Link to comment Share on other sites More sharing options...
Blue502 Posted March 18, 2012 Share Posted March 18, 2012 Other then the shift kit there is not a lot you can do without pulling the trans.Just make sure you get a large cooler and place it in a direct air flow area in front of the fan for when the car is idling in traffic on a hot day.A trans temp gauge is a good idea.Even stock the 400 is a tough trans. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted March 28, 2012 Share Posted March 28, 2012 Piece of mind says a hardened input shaft ($300 min), a hardened sprag ($250 min) will do the trick, but reality is a good working 400 should handle 700 hp all day long. I tend to go a little nuts when I build them but my 10 sec Bu struts its stuff through a pretty much stock but rebuilt TH400. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted March 28, 2012 Share Posted March 28, 2012 Piece of mind says a hardened input shaft ($300 min), a hardened sprag ($250 min) will do the trick, but reality is a good working 400 should handle 700 hp all day long. I tend to go a little nuts when I build them but my 10 sec Bu struts its stuff through a pretty much stock but rebuilt TH400. pretty much what Andy said but as long as you're in there I would add a steel front hub and a case strengthener. The cast hubs have been known to explode under heavy torque loads and the case piece is a simple clip that holds things in place on the inside....probably about $175 total... Quote Link to comment Share on other sites More sharing options...
