ssmonte70 Posted April 14, 2012 Share Posted April 14, 2012 Hi Everyone, I'm in need of some help clarifying something I found today when taking pictures of my Monte. On the passenger side of the Trans there is a metal "tag" attached that has numbers that I recorded below. 414 (upper right corner of tag) 70-CD 7306 (bottom of tag and these numbers/alpha read from left to right) Any help would be appreciated. I can't seem to find anything on this. Thanks-Troy Quote Link to comment Share on other sites More sharing options...
overdrive Posted April 14, 2012 Share Posted April 14, 2012 I have a book that has the codes. 70= 1970 CD= Monte Carlo/Chevelle w/402 ci There is other information out there that may or may not agree with this. You can find the VIN of the car it originally came in stamped on the drvr side, just above the pan. Check here and here. Dan Quote Link to comment Share on other sites More sharing options...
ssmonte70 Posted April 14, 2012 Author Share Posted April 14, 2012 Thanks Dan for the information. This is perfect for the Monte I have. (1970 w/402) I did look on the driver side of the trans and block in a few spots: *right above where the oil filter goes in and that matches my VIN *the block code which matches the proper block for 70 402 Monte *right next to the block code where the block/tranny meet is the VIN again So far everything matches, just wasn't sure about that trans tag and what it meant. Thanks again...Troy Quote Link to comment Share on other sites More sharing options...
overdrive Posted April 14, 2012 Share Posted April 14, 2012 You're welcome. Dan Quote Link to comment Share on other sites More sharing options...
