ejw71 Posted August 29, 2003 Share Posted August 29, 2003 From reading several past posts I've concluded that power window switches for a '71 are different than a '70. Is this correct? Thanks, Ed ------------------ '71 Black 406/700R4/10bolt 2.73 Branson participant '71 Sandalwood SS454 '71 Project Super Dark Green Metallic/346LS1/4L65E/12bolt posi Link to comment Share on other sites More sharing options...
Mr70Monte Posted August 29, 2003 Share Posted August 29, 2003 thats correct. 70 used the old style that was used in the mid to late 60's. 71, started using the new style that was used up until the late 70's. there is a pic of the 70 style in my pics on CarDomain (use my link in my signature), go to page 3. the 71 style has a more square body. ------------------ '70 Monte Carlo, Forest Green Metallic w/black vinyl top, Dark Green Metallic Interior community.webshots.com/user/wv_moonshiner http://www.cardomain.com/id/mr70monte If you see this car on a trailer, call 911, because it's stolen! Link to comment Share on other sites More sharing options...
montefrazer Posted August 30, 2003 Share Posted August 30, 2003 Power lock switches also match the power window switches for 70 and 71-72. As usual, 70 is the odd one. The two styles are interchangeable and will work fine. Just look different. ------------------ Steve Link to comment Share on other sites More sharing options...
ejw71 Posted September 3, 2003 Author Share Posted September 3, 2003 Thanks, Steve. Put'n '70 power windows in '71 454SS. Just will have to exchange the switches, correct? Ed ------------------ '71 Black 406/700R4/10bolt, Branson participant '71 Sandalwood SS454 '71 Project Darkest of Dark Green Metallics/GenIII346LS1/4L65E/12bolt posi Link to comment Share on other sites More sharing options...
montefrazer Posted September 4, 2003 Share Posted September 4, 2003 That's right. Recently tested a set of 71 up switches in my 70 to see if they worked. Plugged in and worked fine. ------------------ Steve Link to comment Share on other sites More sharing options...
