Newb Posted February 27, 2013 Share Posted February 27, 2013 Can anyone help me out? I'm converting my 72 from a column shift to a factory console and I purchased the tranny cable bracket from opgi and I'm not sure where it mounts to the tranny? Link to comment Share on other sites More sharing options...
Leghome Posted February 27, 2013 Share Posted February 27, 2013 Mine is mounted to a couple of the pan bolts. My 72 is in the shop right now so I cannot tell you which two bolts they are. After everything is mounted top side and the cable is hooked to the tranny linkage I think the location could be found. Link to comment Share on other sites More sharing options...
footballubet Posted February 27, 2013 Share Posted February 27, 2013 It will just about fall in place on the trans pan bolt holes. Link to comment Share on other sites More sharing options...
Newb Posted February 27, 2013 Author Share Posted February 27, 2013 I figured that but the one portion of the bracket did not sit flush into the recessed portion of the oil pan and I wasn't sure if that was normal. Link to comment Share on other sites More sharing options...
Heff Posted February 28, 2013 Share Posted February 28, 2013 Not 100% sure but I think the bracket is different for a 350 vs 400 trans. maybe that it? Link to comment Share on other sites More sharing options...
Leghome Posted February 28, 2013 Share Posted February 28, 2013 I know the bracket is different for the 700R4. At least my Shiftworks kit looked different. Link to comment Share on other sites More sharing options...
Toppless72 Posted February 28, 2013 Share Posted February 28, 2013 Heff is correct. The brackets are different for the 350 vs. the 400. The shape of the bracket is different and the bolt hole spacing is different too. Link to comment Share on other sites More sharing options...
