Ember Posted July 20, 2013 Share Posted July 20, 2013 We have the new RamJet 350 in, but when we want to shut it off, a main power lead has to be taken off the battery to kill it. Suggestions? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 20, 2013 Share Posted July 20, 2013 sounds like you have you ignition feed to a constant 12 volt source, you need to hook it to a ignition feed so it will cut the power when you turn the key off Quote Link to comment Share on other sites More sharing options...
wallaby Posted July 20, 2013 Share Posted July 20, 2013 I had that problem when I added an electric fan setup. It turned out that the fan rotation was generating a current and supplying the ignition circuit with power after the key was shut off. By itself, the fan was wired correct, and by itself the ignition was wired correct....but because the two systems were connected together at the IGN terminal on the fuse block, the fan would power the ign after the key was shut off. This is called backfeeding. It didn't take a high amount of current to keep the ignition working...a couple of volts was enough. For my situation a diode was required in the fan circuit to prevent the current from flowing back to the ignition circuit. Without the diode the voltage was free to run through the wiring in either direction. If this sounds like it could be your problem, I can diagram how to install a diode that is easy to put in and doesn't require the full amperage of the fan motor through it. Look into what other stuff you may have connected to the IGN terminal of your fuse block...one of those items may be sending a small voltage back and keeping the engine running. Quote Link to comment Share on other sites More sharing options...
