tonym0828 Posted October 5, 2013 Share Posted October 5, 2013 Put new circuit board in and all new bulbs. Now some of them work and a lot do not. could the copper tabs on the sockets need bent up or am I better off buying a bunch of new ones. All help or suggestions appreciated. Thank you Tony Murphy Quote Link to comment Share on other sites More sharing options...
monte70car Posted October 5, 2013 Share Posted October 5, 2013 Tony was the bulbs you use the stock ones and were they already in the car? Stock ones doesn't matter which way they are put in as they will still work. Testing them you should be able to use a 9volt battery to test them. If you have the LED bulbs they will need to go in one way and again can be tested with a 9volt battery. Quote Link to comment Share on other sites More sharing options...
tonym0828 Posted October 5, 2013 Author Share Posted October 5, 2013 No I bought all sylvania 194's new and the sockets all were in the dash Quote Link to comment Share on other sites More sharing options...
cbolt Posted October 6, 2013 Share Posted October 6, 2013 I had similar issues with a brand new printed circuit. I wound up just working the bulb socket on and off a few times to get them all to work. It was like a film of some sort had built up during storage or shipment on the printed circuit. Probably result of slight corrosion. If it is really bad you can take a pencil eraser to the copper tabs and on the contact area of the printed circuit to make the contact better. That is the least abrasive way to get the connections clean and establish a good connection. Quote Link to comment Share on other sites More sharing options...
footballubet Posted October 6, 2013 Share Posted October 6, 2013 After you get them all working apply a dab of dielectric grease on the contacts to prevent any future corrosion from building up. Quote Link to comment Share on other sites More sharing options...
tonym0828 Posted October 6, 2013 Author Share Posted October 6, 2013 thank you very much I figured It was probably something I never would think of. glad I did not completely put it together. Quote Link to comment Share on other sites More sharing options...
