Message Board
2018 Western Meet
[clock1]
2018 Eastern Meet
[clock2]
Car stereo
  • Please log in to reply
12 replies to this topic
#1 mikeringland
mikeringland
    Junior Member
  • Members
  • 95 posts
  • LocationNorth Chelmsford, MA
  • Legal Name:Michael Ringland
  • Occupation:IBEW Local 103 Master Electrician
Posted 13 January 2018 - 05:10 AM
Has anyone here used the Vintage Car Audio 300 series stereo in their Monte? Do you like it, any issues?
I currently have a Custom Autosound 630 and have had nothing but problems with it.
I'm open to other brands if anyone has a suggestion. I'm looking for a stereo that will fit in the stock radio slot in the dash, that I can plug an IPod into and has at least one set of RCA outputs for a bass tube.
#2 stangeba
stangeba
    Original Owner
  • Members
  • 4,766 posts
  • LocationShelby Township, Michigan
  • Legal Name:Bruce Stange
  • Occupation:Retired from E. I. DuPont Automotive Finishes still working at Langdon's Stovebolt Engine Parts Company.
Posted 13 January 2018 - 09:20 AM
Just found my receipt from 7 Aug 1996!
I paid $422.94 for a Custom Autosound Kenwood 800 Radio, ($399.00 + Tax)
It has a cassette tape player and I have a 6 disc CD changer in the trunk, works great!
I still have my original AM/FM Stereo in the basement (and one from a 73 Buick I think)
Good tunes!
Posted Image
Original Owner since May 14 1971
#3 Rock
Rock
    Bronze Member
  • Members
  • 1,887 posts
  • LocationMinnesota
  • Legal Name:Glen
  • Occupation:Technician
Posted 13 January 2018 - 01:43 PM
I have the 630 and I have had no issues. What problems have you had? Only thing I wish I would of done was spend the extra money for Bluetooth.
Posted Image
Nothing special about this Monte. No SS, no rare options just a super sweet car to drive and take me back to the good old days!
#4 mikeringland
mikeringland
    Junior Member
  • Members
  • 95 posts
Posted 13 January 2018 - 02:04 PM
I've had two issues, one is resolved, one is not.
The first issue I had was the right knob stopped working, so I couldn't skip a track on the Ipod or adjust bass, treble, etc. Custom Autosound sent me a new knob and I had to take the radio out of the car, open it up and replace the knob. They were very quick to send me a new knob, which made me think this is a common issue with them.
The second problem I have is a little more complex. I converted my original points ignition to an HEI system. Nothing fancy, just a GM stock HEI setup. Since then, when the car is running, the radio sound cuts in and out almost like a CD skipping. It does it both on FM and Ipod. I checked everything, speaker wires, speaker connections, ground, power, battery, without a solution. I just found out in the last few weeks that HEI can cause RF interference, which the USB and Ipod cables that are on the 630 radio can pick up and cause the radio to malfunction. I purchased a set of ferrite beads to put around both the USB and Ipod cables coming out of the radio. This is supposed to solve the issue. I get them on Monday, we shall see if that solves it.
Googling around about this RF issue also lead to me an online thread where the general consensus was if you need to add ferite beads to your radio because an HEI system is causing interference, your radio is a piece of junk, more or less.
Hopefully this ferrite bead trick will work and I can just keep the 630 radio, which would be nice, considering I spend 300 bucks on it.
Mike
#5 Rock
Rock
    Bronze Member
  • Members
  • 1,887 posts
  • LocationMinnesota
  • Legal Name:Glen
Posted 13 January 2018 - 03:04 PM
I have HEI ignition and I have not experienced those issues but I don’t use an IPod much at all but I use my IPhone all the time. It has never cut out. Maybe you got a bad connection or wiring issue to the radio or something inside the radio like a bad solder joint.
Posted Image
#6 mikeringland
mikeringland
    Junior Member
  • Members
  • 95 posts
Posted 13 January 2018 - 03:21 PM
Honestly, the radio worked perfectly fine before I did the points to HEI conversion. The RF interference is the only viable culprit. When the engine is off and the key is in the on position, the radio works great.
#7 stangeba
stangeba
    Original Owner
  • Members
  • 4,766 posts
Posted 13 January 2018 - 03:25 PM
Mike,
Did you remove the resistor that is required with a stock points dist?
I have NO idea if that would cause your problem, but I know it needs to be removed when using a GM HEI system.
Bruce
Posted Image
#8 Rock
Rock
    Bronze Member
  • Members
  • 1,887 posts
  • LocationMinnesota
  • Legal Name:Glen
Posted 13 January 2018 - 03:41 PM
If it is interference than a choke will fix it.
Posted Image
#9 mikeringland
mikeringland
    Junior Member
  • Members
  • 95 posts
Posted 13 January 2018 - 05:13 PM
Bruce,
Yes I did remove the original resistor wire during the HEI conversion, and ran a new ignition power wire.
Mike
#10 monte70car
monte70car
    Chrome Member
  • Members
  • 8,935 posts
  • Locationalexandria,va
Posted 15 January 2018 - 07:30 AM
I put this one in my 72 ]http://www.chevelle....00&maxWidth=300 picked it up here http://www.chevelle.com/1971-72-AMFM-Radio-P5581.aspx when its off the display is black. I've tested the radio with just one speaker and it does have good sound playing through a 4" 100 watt speaker.
robert
#11 mikeringland
mikeringland
    Junior Member
  • Members
  • 95 posts
Posted 20 January 2018 - 02:35 PM
Problem solved. Added ferrite beads to the radio 12v ignition and 12v battery wires. Also added ferrite beads to the USB cable on the radio. Nothing, no change. Looked under the dash one more time and saw the tach wire laying on the 12v radio ignition wire, unplugged the tach from the distributor, problem gone. Unbelievable, haha. Have to reroute the tach wire now.
#12 bigtankjones
bigtankjones
    1st gen Monte Lover
  • Members
  • 3,219 posts
  • LocationBay City, Mi
  • Legal Name:Tony Jones
  • Occupation:skilled trades(uaw machine repair)
Posted 21 January 2018 - 06:19 PM
I have the 630 also and have had no issues with mine. I've adapted the 70 style knobs to my controls. I just need to upgrade to some better speakers.
It's a Monte thing. You just wouldn't understand.
1970 Monte Carlo, Big Block 454.
#13 72Ragtop
72Ragtop
    Member
  • Members
  • 239 posts
  • LocationLoveland, Colorado
  • Legal Name:David C. Winters
  • Occupation:Abused taxpayer
Posted 22 January 2018 - 01:42 PM
I have a 3/4" thick file covering Custom Auto Sound and all the problems, issues, returns, re-returns and (worst) the total lack of any customer service. Now that was about 10 years ago, but it still makes me sick when I see them on TV or in advertising. I currently have an actual Am-FM-Cassette-Remote CD Kenwood (KRC-3007 w/ two actual Knobs!!!!) Love it!!! And I have a spare in the attic.
Home Page
Message Forum
Members' Montes|Meet Photos
