jayzi Posted October 21, 2013 Share Posted October 21, 2013 Hi guys. After removing the holder plate of the A/C compressor I have found two not connected cables which seem to belong to a part which I would say is the oil sending unit. It's on the drivers side near the spark plugs. There was a female connector stuck on it which can't be used anymore so I probably will try to reconnect the cables with single connectors instead. There is a green and a green-white cable hanging around. Is it important to know which one belongs to which contact or is it interchangeable? Quote Link to comment Share on other sites More sharing options...
Leghome Posted October 22, 2013 Share Posted October 22, 2013 That is where my temp gauge is located. Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted October 22, 2013 Share Posted October 22, 2013 That is the temp. sending unit between the spark plugs. The oil sending unit is on the top of the engine block in the rear below the distributor. It should have a single dark blue wire going to it. On this unit it does make a difference which wire goes on which side. Look at a 1971 wiring diagram to determine which way it goes. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 22, 2013 Share Posted October 22, 2013 nope that is the sending unit for the TSC (transmission spark control) temp sender has 1 wire, the oil pressure one is back by the distributor Quote Link to comment Share on other sites More sharing options...
VE3HZZ Posted October 22, 2013 Share Posted October 22, 2013 That is what I was puzzled on with this being a 71 was not sure but never noticed 2 wires on temperature sending units or oil ones either as they ground to the vehicle (and what more ground can you have then a giant hunk of iron) Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted October 22, 2013 Share Posted October 22, 2013 Sam you are correct. I just noticed I wrote the wrong thing in my first post. If I write one thing while thinking another does that mean I'm getting OLD!!! LOL Sorry for the confusion. Quote Link to comment Share on other sites More sharing options...
jayzi Posted October 23, 2013 Author Share Posted October 23, 2013 Look at a 1971 wiring diagram to determine which way it goes. Is that anywhere available online (for free)? Originally Posted By: Sam (Bones) nope that is the sending unit for the TSC (transmission spark control) I have no knowledge about that thing so I'm curious what happens if the cables are not connected? Quote Link to comment Share on other sites More sharing options...
Toppless72 Posted October 24, 2013 Share Posted October 24, 2013 I'm not too good at creating links but if it works, I believe this will help you. 1971 chevelle wiring It takes a minute to load but its worth the wait. just give it time. Also, make sure you look at all the pages of the post. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted October 24, 2013 Share Posted October 24, 2013 I have no knowledge about that thing so I'm curious what happens if the cables are not connected? that depends on if the rest of the system is hooked up it holds off vacuum advance until in third gear, I think it doesn't operate until the engine reaches operating temperature Quote Link to comment Share on other sites More sharing options...
LostnFound Posted October 24, 2013 Share Posted October 24, 2013 new switch on Ebay for $24.99 with free shipping... http://www.ebay.com/itm/CHEVROLET-OLDSMO...0-/231076988592 Quote Link to comment Share on other sites More sharing options...
jayzi Posted October 24, 2013 Author Share Posted October 24, 2013 1971 chevelle wiring Thanks Joe. While I couldn't find what I'm looking for it will help me with other eletrical tasks. Originally Posted By: LostnFound new switch on Ebay for $24.99 with free shipping... http://www.ebay.com/itm/CHEVROLET-OLDSMO...0-/231076988592 Great find. So on the photos it's clear to see that it's only one connector with two pins. That would mean I can connect the two cables my way. Quote Link to comment Share on other sites More sharing options...
