footballubet Posted February 21, 2014 Share Posted February 21, 2014 Looks great. Made a big difference from what it looked like. Quote Link to comment Share on other sites More sharing options...
Rock Posted February 21, 2014 Author Share Posted February 21, 2014 Thanks guys. The old one was destroyed by what looks like water damage. I ended up cleaning up the metal from some minor surface rust and sealing it with some epoxy paint. Then I cut 1/4 hardboard to fit the area which I made a cardboard template. After getting the perfect fit I cut out the 6 x 9 holes for the speakers. Then to make sure the grills fit correctly I drilled from the underside of the package tray. Then I glued the carpet down and trimmed to fit. Only took me 2 weeks to deal with this snowball. But it was worth it to get some great results. The back window leak has been fixed by previous owner so I should be good now. Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted February 21, 2014 Share Posted February 21, 2014 That looks GREAT! Nice job, Rock. Quote Link to comment Share on other sites More sharing options...
Rock Posted February 21, 2014 Author Share Posted February 21, 2014 That looks GREAT! Nice job, Rock. Thanks Bob....the one thing I wish I would of done after installing it was paint the board where the 6 x 9 opening is or glued some fine mesh black screen over the holes....when you look through the back window you can see the board through the speaker grills!! Quote Link to comment Share on other sites More sharing options...
Hoodicoff1 Posted February 24, 2014 Share Posted February 24, 2014 _DSC0065 by Hoodicoff, on Flickr I used 3/8 masonite and some black speaker box carpet to build up a new package tray, also covered the whole shelf with some B-quiet, you can also get some black vinyl if you want more of an 'Original' look Quote Link to comment Share on other sites More sharing options...
Rock Posted February 25, 2014 Author Share Posted February 25, 2014 _DSC0065 by Hoodicoff, on Flickr I used 3/8 masonite and some black speaker box carpet to build up a new package tray, also covered the whole shelf with some B-quiet, you can also get some black vinyl if you want more of an 'Original' look Your car is awesome....i need to see this one in person! I thought about the stuff they use on sub boxes.....the stuff I seen looked a little thin and you could see the backing. Quote Link to comment Share on other sites More sharing options...
Hoodicoff1 Posted February 27, 2014 Share Posted February 27, 2014 Hopefully I will make it to a western meet as soon as I work all the bugs out of er! I sure would like to meet some of guys in real life. The stuff I use for sub boxes and other interior panels is a super stretchy non backed material, it molds quite well to pretty much anything. Most good car audio places should have the material. I found a site that carries the stuff as well http://www.yourautotrim.com/80wideozite.html Quote Link to comment Share on other sites More sharing options...
