shoalssales Posted May 10, 2014 Share Posted May 10, 2014 Ok i have a 1973 454 that is bored out 30 over with new flat top pistons stock heads and a comp cam, aluminum edelbrock intake and holley 750 carb. I have rebuilt 700r that is supposed to hold up to 450 hp and was wondering what a good torque converter and stall would be? Any suggestions? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 10, 2014 Share Posted May 10, 2014 depends on the cam specs Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 All of this is going in a 72 monte carlo that will be used as a daily driver and will never see a drag strip. I wasn't sure if a stock convertor would be ok. Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 Intake Exhaust Duration at .050 218 224 Lobe lift .2970 .3030 Lobe separation 112.0 Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 Well that is supposed to be my cam specs if you can read it Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 10, 2014 Share Posted May 10, 2014 a stock converter would work fine for those specs Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted May 10, 2014 Share Posted May 10, 2014 Pretty mild cam stock converter should work. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted May 10, 2014 Share Posted May 10, 2014 Beat me to it Sam! Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 Ok my motor came out of a 73 caprice wagon and I know they didn't come with a 700r4 back then and my 700r4 is a 91 model so what stock car convertor should I get? Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 And what kind of hp do you think this motor will have? Thanks I appreciate everybody's help Quote Link to comment Share on other sites More sharing options...
shoalssales Posted May 10, 2014 Author Share Posted May 10, 2014 I know a guy that rebuilds stock converters but I'm not sure If I should get a 1500 stall or a 2400 or just get a stock convertor from a parts store. Quote Link to comment Share on other sites More sharing options...
footballubet Posted May 10, 2014 Share Posted May 10, 2014 Make sure you get a 30 spline converter. The earlier trans used a 27 spline input shaft. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 10, 2014 Share Posted May 10, 2014 I would say a 1800-2000 stall you're probably in the neighborhood of 350+ HP, but it will make great! torque Quote Link to comment Share on other sites More sharing options...
