JOHNR Posted May 31, 2014 Share Posted May 31, 2014 HI I need to know if a 700R4 will fit on a 92 firebird with a v6? I believe the v6 came with a 200r4 without any changes or modifucations? THanks Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted May 31, 2014 Share Posted May 31, 2014 Is it the 4.3? Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted May 31, 2014 Share Posted May 31, 2014 I believe a 700 has a multi-fit bellhousing, if it does, it should fit Quote Link to comment Share on other sites More sharing options...
Patrick Sheean Posted May 31, 2014 Share Posted May 31, 2014 Isn't the 700r4 longer? Are you just talking about the engine or the car too? That kind of change will take some other modifications (cross member, driveshaft length). Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted May 31, 2014 Share Posted May 31, 2014 I thought I remembered reading it bolted to the 4.3, not sure on any of the other specifics like driveshaft and all though Quote Link to comment Share on other sites More sharing options...
JOHNR Posted June 1, 2014 Author Share Posted June 1, 2014 Once again the question is will the 700r4 fit Ina 1992 firebird with a 3.1 liter v6? The difference being the 700r4 came with the same car but the engine was a 5.7 liter or 350cubic inch engine. John I know the tail piece may be a different length but not sure. Quote Link to comment Share on other sites More sharing options...
7tonemonte Posted June 1, 2014 Share Posted June 1, 2014 You didn't say which v6 in the first post. I just remembered reading somewhere over the years someone using it on the other motor, try asking on one of the firebird forums, they are probably like the Monte owners and had tried everything! Quote Link to comment Share on other sites More sharing options...
