cbolt Posted September 8, 2014 Share Posted September 8, 2014 I purchased an AutoMeter electrical oil pressure gauge and noticed the sending unit has clearance issues. SBC with a Weiand intake and electronic distributor. Instead of trying to re-invent the wheel I figured I would ask how other people solved the sending unit relocation. It appears the standard 2" adaptor from Jegs or Summit will still create issues with the distributor so I am looking at a braided hose and clamp to put the sending unit on the firewall. Does anyone else have this setup? Does the adaptor provide enough clearance to forgo the tube and clamp method? Should I look at a 90 degree elbow fitting? Thanks in advance. Jim Quote Link to comment Share on other sites More sharing options...
cbolt Posted September 9, 2014 Author Share Posted September 9, 2014 My engine doesn't seem to have the extra port. Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 10, 2014 Share Posted September 10, 2014 I used a 45 degree fitting for my sending unit. Not sure how much room you have or need. Quote Link to comment Share on other sites More sharing options...
cbolt Posted September 10, 2014 Author Share Posted September 10, 2014 I probably have the same clearance everyone else has with a aluminum intake and HEI distributor. I did some rough measurements and I will need the longer adaptor to make room for the 90 degree fitting anyway. Quote Link to comment Share on other sites More sharing options...
rsorg Posted September 11, 2014 Share Posted September 11, 2014 I also used a 45 degree brass male by female fitting on my bb then put the sender in that. Quote Link to comment Share on other sites More sharing options...
cbolt Posted September 12, 2014 Author Share Posted September 12, 2014 I solved it with a stainless adaptor from Jegs and a 90 degree elbow. Fits under the distributor and over the manifold just fine. Only thing left prior to installation is pre-oil and thermostat install. Quote Link to comment Share on other sites More sharing options...
footballubet Posted September 12, 2014 Share Posted September 12, 2014 Good progress! Can't wait to hear it fired up. Quote Link to comment Share on other sites More sharing options...
rsorg Posted September 16, 2014 Share Posted September 16, 2014 I forgot to add the 45 degree brass fitting I used was right above the oil filter on the block, works great Quote Link to comment Share on other sites More sharing options...
