Bob Hansen Posted June 23, 2004 Share Posted June 23, 2004 Well it's not the Monte, it's a daily driver 87 GMC 1500 4X4 6100 GVW 5.7 (355 now) anyway about 45000 miles ago I paid $1800 to get the tranny rebuilt. Currently the shifts are soft and fluid is turning bad. Has heavy duty trans cooler don't use overdrive when towing / hauling loads. Question: Could simple clutch pack wear be the problem or could there be a valve body issue causing a drop in pressure? My guess is the place that rebuilt it, shafted me & did a half baked job for full price. I am debating pulling the trans out my self & having it re-rebuilt although I doubt that a $2500 truck is worth putting a $1200 or $1400 trans job in. (especially since I would need to borrow the money) Maybe I should change the fluid & sell it??? Quote Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2004 Share Posted June 24, 2004 550$ can get you a pro street ready 700r4 trans mission from place in missouri. Quote Link to comment Share on other sites More sharing options...
Bob Hansen Posted June 24, 2004 Author Share Posted June 24, 2004 Yea, I was checking on ebay this morning add some for 4x4 add $250 for core charge add $230 for shipping, etc. but at $995 that is still better than the 12 to 1400 I was quoted locally. Bob Quote Link to comment Share on other sites More sharing options...
Guest Posted June 24, 2004 Share Posted June 24, 2004 all the 4x4 stuff off the other 700r4 should swap over. its just bolted onto the end of it. Quote Link to comment Share on other sites More sharing options...
Charlie72 Posted June 24, 2004 Share Posted June 24, 2004 if the place you took the tranny to did not reset the T.V. cable that would cause a burnout. anytime the tranny is serviced/rebuilt, this adjustment needs to be made. Quote Link to comment Share on other sites More sharing options...
ejw71 Posted June 24, 2004 Share Posted June 24, 2004 Bob, I was shafted twice by two different auto trans guys. Plan on rebuilding my TH350. Unable to rebuild 700R4s or 2004Rs as they require many special tools. Ed Quote Link to comment Share on other sites More sharing options...
monzaz Posted June 25, 2004 Share Posted June 25, 2004 I got mine done here in ohio for 795.00 about 4 years ago ...kevlar band shift kit 2000 stall b&m lock up kit behind a big block I drag race it with slick and with out 13.45 with out slicks and 3.31 gears and 12.80's with slicks and 3.31 gears. Shipping would be the killer. I think he charges 150.00 for a core if you do not have one. Jim I can get a number if you are interested and even pick up and ship reasonable if you would like I shipped a tranny through DHL for 66.00 in a wood crate. NO converter though. mitschke454@earthlink.net Quote Link to comment Share on other sites More sharing options...
