Big Al Posted October 15, 2015 Share Posted October 15, 2015 When I pull the headlight switch inside my car and turn the key forward towards the start position, the left turn signal light indicator on the dash lights up and the leftfront park lamp/turn signal will not come on. when I move the turn signal lever to the left position the park light comes on. None of the turn signals are working. The front headlights,rear lights and marker light are working. I have been troubleshooting and I found a couple of things and corrected them but I haven't been able to fix's this problem. Do anyone have any suggestions or have had a similar problem like this before? I have just installed/re-wired the car with a American Auto wiring kit. Quote Link to comment Share on other sites More sharing options...
monte70car Posted October 15, 2015 Share Posted October 15, 2015 Al have you check the ground connection? Also try and move the bulbs. Quote Link to comment Share on other sites More sharing options...
Big Al Posted October 16, 2015 Author Share Posted October 16, 2015 Monte 70car, After doing some troubleshooting I was finally able to find the problem. It turns out when I had my car paint, I also removed the engine and had the engine bay painted. After cleaning the paint from around all of the grounding points it fixed the problem. Thanks again for all of your help. Quote Link to comment Share on other sites More sharing options...
monte70car Posted October 16, 2015 Share Posted October 16, 2015 Not a problem Al. Quote Link to comment Share on other sites More sharing options...
stangeba Posted October 16, 2015 Share Posted October 16, 2015 Good to hear it's fixed. So many automotive electrical problems are due to poor or missing grounds. IMO it is the #1 cause. Bruce Quote Link to comment Share on other sites More sharing options...
