dyermullet Posted March 24, 2020 Share Posted March 24, 2020 I searched but can't find anything. Does anyone have a picture of how the stock style throttle cable connects to the gas pedal? The pedal doesn't have a slot, I don't understand how the cable attaches when you can't hook it onto the pedal. Cable was all screwed up on the car when I bought it so I replaced it with a lokar. Seems like the lokar are only for show cars. I close to daily drive the car, the inner cable wore into the outer and keeps causing the throttle to hang open. I was able to get the lokar to work from dissemble it, install the outer then thread the inner cable through the pedal, then through the outer jacket. I bought a new factory style cable and bought a new split plastic retainer https://www.ebay.com/itm/1968-79-GM-Accelerator-Throttle-Cable-Lock-Ring-Retainer-at-Gas-Pedal-arm-403929/201333056091?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649 Once I take the Lokar cable out of the pedal I am committed to replacing because can never get the inner back into the outer. It's my only running/driving car at the moment so don't want to take it apart until I know i can get it back together. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted March 24, 2020 Share Posted March 24, 2020 Ez pz. Doesn't the new stock cable assy have the nylon retainer already? If it does, Take the split plastic/nylon retainer off the stock cable. If not, Insert the stock cable through the eyelet/hole on the stock gas pedal. Install the retainer back/onto the cable and snap it into the gas pedal and then pull cable tight. Installed! This is after snapping the cable from the engine side onto the firewall . Hope this helps. Quote Link to comment Share on other sites More sharing options...
dyermullet Posted March 24, 2020 Author Share Posted March 24, 2020 It sure looks to me like the end of the cable is larger than the hole in the pedal. I will have to get back under the dash with all the parts and look again. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted March 24, 2020 Share Posted March 24, 2020 The piece on the pedal side is slotted and look like this. Quote Link to comment Share on other sites More sharing options...
dyermullet Posted April 14, 2020 Author Share Posted April 14, 2020 I was able to get the cable changed out yesterday evening. Turns out the nylon retainer was still in the pedal. I knew the hole in the pedal wasn't big enough, that is because the retainer was still in place. Good thing I bought a new one because the old retainer disintegrated when I removed it. 1 Quote Link to comment Share on other sites More sharing options...
