70Caprice GreenBoat Posted November 16, 2023 Share Posted November 16, 2023 I am having hard time finding the short length AGC 3A fuse for Inst. LMPS ( interior instrument cluster). Mine blowed when I was washing the car, taking out power to outlet plug/ cigaret lighter I use to plug in GPS Speedometer, phone charged etc… There are Christmas’s light fuses that are short but not the same diameter. Listed as either 120V/250V 3A slow or fast blow. Would those substitute? Would someone have a source of these fuses, main auto parts stores 0(Zone, Adv, O’R*) stopped stocking these? thanks in advance, ’70Caprice Quote Link to comment Share on other sites More sharing options...
jft69z Posted November 16, 2023 Share Posted November 16, 2023 Look for either 'AGA 3' or 'SFE-4' fuses. Those are the correct dimension you're looking for. The AGC you mentioned will come back as a full size fuse in searches. SFE doesn't come in a size smaller than 4, however, the owners manuals I have for 71 & 72 show the fuse rated at 4 amps for that location (it should also be on the fuse block itself, to the left of the fuse - "4A"). Perhaps a 70 is different, that I don't know off hand. Amazon, NAPA will have the SFE. If you happen to have an under hood lamp with the inline fuse holder, the SFE-4 is the correct fuse for that application as well. The fuse pictured in front of the boxes came from an old harness out of my 72. https://www.napaonline.com/en/p/BK_7821070 https://www.amazon.com/Bussmann-Division-SFE-4-Auto-Fuse/dp/B000CF9G80?th=1 https://www.eaton.com/content/dam/eaton/products/electronic-components/resources/data-sheet/eaton-sfe-fuse-data-sheet.pdf 4 Quote Link to comment Share on other sites More sharing options...
