Guest supercoupe5 Posted July 16, 2008 Share Posted July 16, 2008 i took the egine and trans out of my car (350ci and th350). i put in a differand engine and trans (355ci and th400). now when i went to hook up the shift cable from my floor shifter i dont have the bolt holes in the side of the trans case on the 400 that i did on the 350. is there a differant bracket for the 400 or a differant cable or what. info and pics would be great. thanks dave Quote Link to comment Share on other sites More sharing options...
Ian Posted July 16, 2008 Share Posted July 16, 2008 It takes a different bracket, but I think the same cable. You also will need the kick down switch that mounts to the brake pedal bracket as it is electronic. Ian Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 16, 2008 Share Posted July 16, 2008 X2 Quote Link to comment Share on other sites More sharing options...
monte70car Posted July 16, 2008 Share Posted July 16, 2008 x3 the kick down switch mounts the gas pedal. dave ill get you a pic of the switch and bracket later today. i dont think there is a brackey on the trans for the cable as it goes a short distance to the arm on the trans i will double check that as well. here is a pic of the bracket and the switch dave i have to move the car out to check on the cable Quote Link to comment Share on other sites More sharing options...
monte70car Posted July 16, 2008 Share Posted July 16, 2008 here is how my looks the only bracket i see is bolted to the pan nothing on the case and its a 700r4. i believe the 400 should be the same Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 16, 2008 Share Posted July 16, 2008 I'll have to look around and see if I can find my switch and cable bracket Dave, I know that I took them off, just don't know where I put them Quote Link to comment Share on other sites More sharing options...
