New Forum Fields for your Profile.
13 minutes ago, stangeba said:
Joe, Yes, what was the vert. donor car, Chevelle, Cutlass, etc.
Thanks Bruce.
Based on the small percentage of verts out there, I'm not sure it would be worth adding 3 extra slots for that category. The list is already getting long, and probably could have added options to the other categories, but decided against it for the same reason.
I added the Convertible and Clone/Tribute fields to the list this morning.
If there are any issues or more suggestions, let me know.
Thank you!
  • 3 months later...
For whatever reason, the 'My Montes' profile field requirement had defaulted back to 'not required' on its own. Noticed this with a couple of new member registrations, so it has now been turned back on. As in the past in rare instances, there may be a message requiring you to simply fill out that field. If there are any difficulties, let me know.
Thank you,
Joe T
  • 1 month later...
26 minutes ago, 71MonteCarloMD said:
Joe, it asked me to complete my profile and asked me for my Veteran status as I am not a veteran, seems no option to say not a veteran?
You should just be able to go right past it. I'll look it over though.
32 minutes ago, 71MonteCarloMD said:
Joe, I’m not sure if that’s only item that is waiting for me to complete as it shows that I’m at 50%?
There are fields that aren't mandatory. If you don't want to fill them out, just bypass them and you should be able to proceed. I looked your profile over earlier and all appeared to be ok.
I poked around again just now and all appears to be in order. Is it prompting you each time you log in to complete your profile?
  • Thank You! 1
