LS swap fuel pump question
ouch
I have on order a carbureted LS 427 from Blueprint and will need an electric fuel pump. Will a Holley Blue pump be enough? Is anyone using this successfully with no return line?
I have used that fuel pump with my carbureted (at the time) LS6 454 engines in both my old Monte & current Z/28. No problems at all, and I also used their fuel regulator to knock down the pressure too..
Like Joe stated that pump will work with a regulator.
I would also suggest 1/2" fuel line from the tank to the carb to feed the beast if you do not have that already.
Also a sump in the tank or the option I took for "Big Red" which is a 1/2" sending unit from RobMC that has an extension towards the back bumper. This way you can run a stock fuel tank.
