Hoodicoff1 Posted December 14, 2006 Share Posted December 14, 2006 I am currently getting a 700r4 built for my car, but the turb0 400 thats in the car right now is dead. It worked just perfect when it came out of the chevy van, then when I put it into th Monte I got nothing, if I put the car on jacks itll move the wheels just fine, get the car going 90 miles an hour in third gear on blocks bust as soon as it gets put on the pavement absolutley nothing. I did put a shift kit in it so I bet I monkeyed something up, anything to look for to make it do something? Quote Link to comment Share on other sites More sharing options...
Heckeng Posted December 14, 2006 Share Posted December 14, 2006 That can be extremely contageous, I'd give that tranny away asap!!! I'll send you my address so you can get rid of it! Seriously, it sounds like you probably just got a checkball in the wrong spot, or forgot to put one in. I would bet that if you dropped the valve body and re-looked at the instructions, you'll find the culprit. Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted December 20, 2006 Share Posted December 20, 2006 That is very weird. I have never heard of that happening before Quote Link to comment Share on other sites More sharing options...
Guest Posted December 20, 2006 Share Posted December 20, 2006 Well at least you did not break the speedo... When you did the swap did you change the converter? If so did you turn it until it clicked into the transmission or just slap it in and bolt it up? Quote Link to comment Share on other sites More sharing options...
Hoodicoff1 Posted December 20, 2006 Author Share Posted December 20, 2006 Im pretty sure thats what it is, no torque, means no torque convertor, it clicked in twice, if it wasnt fully engaged the engine and tranny wouldnt go together properly am I right? the torque convertor got water in it when it was sitting for a while too, no matter now because its coming out and a built 700r4 is takin its place Quote Link to comment Share on other sites More sharing options...
Guest Posted December 21, 2006 Share Posted December 21, 2006 Partly correct, it would fit toghether although it would stack the transmission pump if it did not click in. Then it would be no good kind of like the one you have now. Quote Link to comment Share on other sites More sharing options...
