kc8oye Posted November 18, 2009 Share Posted November 18, 2009 Konik's Klassiks now has the ability to convert column shift columns into floor shift columns! First we start with a standard column: then we shave off the column shift nub: and finally we fill and paint the hole Stay tuned for final pics. once the primer is dry and I can finish up some light sanding I'll get some black paint on there for some finish pics! Quote Link to comment Share on other sites More sharing options...
Chevyss Posted November 18, 2009 Share Posted November 18, 2009 Good, I'll need that to be done when I finish my shifter, and transmission swap. Nice to know that it can be done. I just put a rebuilt column in that I got from Columns Galore. Thanks Time Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 18, 2009 Author Share Posted November 18, 2009 n.p send us the whole column, and we can go thru it and replace anything that needs attention, or if you want to tear the column apart yourself, you can send us just the collar Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted November 18, 2009 Share Posted November 18, 2009 If can definately be done. If Leo does it its right. I seen a column at a swap meet one time, that had that done and at FIRST GLANCE I could tell it. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 19, 2009 Author Share Posted November 19, 2009 from the outside, you can not tell it was modified.. from the inside.. yes.. because we leave pretty much all of the column shift stuff there as there is just no reason to remove it, removing the column shift lever takes care of removing anything necessary to the operation of the column. all of the ignition lockout and steering wheel lock stuff works the same either way. a CORRECT factory floor shift car still has the shifter linkage to the column but they call it a "back drive rod" so that when you put the car into park, you can rotate the lock cylinder all the back to 'lock' and remove the key, as well as operate the steering column lock. this will be my last update for a little while.. I'm going to Texas for 10 days for turkey day and visit with family.. I'll finish this project up when I get back :> Quote Link to comment Share on other sites More sharing options...
Chevyss Posted November 19, 2009 Share Posted November 19, 2009 Tim; Have a great trip. What part of Texas?? Quote Link to comment Share on other sites More sharing options...
kc8oye Posted November 24, 2009 Author Share Posted November 24, 2009 Humble, TX.. just outside of houston Quote Link to comment Share on other sites More sharing options...
kc8oye Posted December 6, 2009 Author Share Posted December 6, 2009 okie dokie here we go.. now you get guess which side holds the mods Side 1: . or side 2: . Quote Link to comment Share on other sites More sharing options...
monte70car Posted December 6, 2009 Share Posted December 6, 2009 after looking at the pitcures im going to say side one. noticed the ing. switch part of the col was removed for pictures. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted December 7, 2009 Author Share Posted December 7, 2009 it was removed entirely ert.. not just for the pics. to get that collar off the column it has to be completely disassembled. Quote Link to comment Share on other sites More sharing options...
ROMO Posted December 8, 2009 Share Posted December 8, 2009 How much to get this done? And how long would it take? Looks very very nice..... Quote Link to comment Share on other sites More sharing options...
kc8oye Posted December 20, 2009 Author Share Posted December 20, 2009 If you ship the column to us, It would take about 5 days + shipping time. it's just a matter of waiting for the materials to dry more then labor. you need to talk to the boss man (Leo) about the costs. and t.y for the complients.. we always do the best work we can. Quote Link to comment Share on other sites More sharing options...
