Sam (Bones) Posted March 13, 2010 Share Posted March 13, 2010 Quote Link to comment Share on other sites More sharing options...
MGD72Monte Posted March 14, 2010 Share Posted March 14, 2010 I had a similar problem years ago after the car sat for a long time and I drove it again. After a couple drives, I could no longer get in low gear. I had some tranny shop look at it, but they were clueless. As I recall, I ended up finding it to be a small part/bracket that connects to the horseshoe lever inside the console that was simply loose. I was able to re-adjust it and tighten it down. As suggested in one of the earlier responses, I recommend taking the top off the console and scanning the linkage attachment points, moving the lever back and forth to better spot the problem. If this is the problem, you should be able to notice that the linkage won't always be moving with the lever. I hope that's all it is. Best of luck. Quote Link to comment Share on other sites More sharing options...
Guest Grandchamp Posted March 19, 2010 Share Posted March 19, 2010 Hey guys sorry it took me so long to reply i finally had time to pull my car out and take a look under it the cable on the left side of the tranny was real loose and had been rigged up to work also found out i had a massive leak coming from my front pump or the seal, therefore i took it to my local tranny shop and had them to take a further look they told me my shifter cable needed replacing and so did my front pump so i told them to go ahead and fix it they said the parts labor and everything would run around 250 it seemed like a fair price to me since they do have to drop the tranny and they are supplying the parts does this sound about right??????? Quote Link to comment Share on other sites More sharing options...
Monteman1971 Posted March 20, 2010 Share Posted March 20, 2010 Sounds cheap to me!!! Cable and the pump..good deal Steve Quote Link to comment Share on other sites More sharing options...
Guest Grandchamp Posted March 20, 2010 Share Posted March 20, 2010 thats what i thought too steve hopefully they'll do a good job i've dealt with them alot so maybe thats why they cut me some slack had quite a few trannys rebuilt here Quote Link to comment Share on other sites More sharing options...
