jminor Posted May 31, 2010 Share Posted May 31, 2010 My 70 SS had a new gas tank when I bought it. Two gas lines run from the fuel pump to the tank. There are 2 lines, one 3/8" and one 1/2", on the right side of the tank that run up under the trunk and are open ended. When the tank is filled and driven a few miles, gas vents out the larger hose. Where are these lines supposed to go or can they be plugged? If plugged, will the tank vent through the gas cap then? Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted May 31, 2010 Share Posted May 31, 2010 If you have a venting gas cap, they should. Quote Link to comment Share on other sites More sharing options...
wallaby Posted May 31, 2010 Share Posted May 31, 2010 How about that crazy canister in the backseat area? Maybe they are supposed to go there? Quote Link to comment Share on other sites More sharing options...
overdrive Posted May 31, 2010 Share Posted May 31, 2010 A 70 doesn't have that. Quote Link to comment Share on other sites More sharing options...
jminor Posted June 1, 2010 Author Share Posted June 1, 2010 Would anyone know the original way a 70's gas tank was hooked up? Quote Link to comment Share on other sites More sharing options...
Shadow Gray SS Posted June 1, 2010 Share Posted June 1, 2010 I believe it was a single line to the mechanical pump and a vented gas cap. Sounds like they put on a '72 tank. You could get a charcoal canister for those two lines or cap them off and if you need one get a vented cap here. Just type in gas cap and it should be the first item. Quote Link to comment Share on other sites More sharing options...
jminor Posted June 1, 2010 Author Share Posted June 1, 2010 Thats what I will do.And see how the car runs.Thanks for the info. Quote Link to comment Share on other sites More sharing options...
