luke_501 Posted September 8, 2010 Share Posted September 8, 2010 hey guys recently i have put my motor and tranny along with driveshaft in my car. the shift linkage between steering column and tranny are hooked up. i went to load car on trailor and when i turned it on and put it in gear nothing happened. its an automative and tried reverse as well as drive and nothing happened. what did i forget to do? Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted September 8, 2010 Share Posted September 8, 2010 fluid? Quote Link to comment Share on other sites More sharing options...
luke_501 Posted September 8, 2010 Author Share Posted September 8, 2010 i never thought of that. i know how to check that but how do i go about adding more? Quote Link to comment Share on other sites More sharing options...
Slaman Posted September 8, 2010 Share Posted September 8, 2010 Pour it staight in the filler tube, where the dip stick is that you pull out to check the level. Quote Link to comment Share on other sites More sharing options...
luke_501 Posted September 8, 2010 Author Share Posted September 8, 2010 ok thanks. im still learning and new to alot of this stuff so thanks for your reply. Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted September 8, 2010 Share Posted September 8, 2010 fluid? Poetry man, poerty. Quote Link to comment Share on other sites More sharing options...
Mikstudie Posted September 9, 2010 Share Posted September 9, 2010 Dont over fill and check level with engine running and warm. Quote Link to comment Share on other sites More sharing options...
kc8oye Posted September 9, 2010 Share Posted September 9, 2010 correct procedure for checking it... with the engine off make sure there is fluid on the stick (don't want to idle the engine if the trans is *DRY*) it doesn't matter where.. just so long as it's reading on the stick, but generally speaking should be well past the 'full' mark with the engine off.. start the engine.. you really should let the engine and trans get up to temp.. but if you are that low on fluid that it won't move, you don't want to idle any longer then you have too.... cycle the trans thru ALL of the gears.. pausing for a couple of seconds in each gear.. so that's Park, Rerverse, Nuetral, (Over Drive if you have it) L3 or D, L2, L1.. then back up to park, one gear at a time.. pausing in each gear again.. then with the engine STILL running at idle.. check the fluid level. Quote Link to comment Share on other sites More sharing options...
luke_501 Posted September 9, 2010 Author Share Posted September 9, 2010 thank you guys so much! i havn't had time to try any of this yet but i am very excited now and can't wait! Quote Link to comment Share on other sites More sharing options...
