71monteme Posted December 27, 2010 Share Posted December 27, 2010 this question is for you guys running aluminum heads and solid roller cam. my cam spec a .030 valve lash hot. i did it cold to get the engine running. on the iron heads the valve lash cold and hot were only a few thousands different. so i usally set them at .028 and forget about them, how much of a different does aluminum makes and which way does it go- make the lash tighter or looser. thanks. thanh Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted December 27, 2010 Share Posted December 27, 2010 My heads seem to be about .006 tight when cold. I also noticed a long time ago that cast iron were a little loose when cold just about .0015 to .002 probably the difference between the cast iron and steel pushrod and lifter expansion rate. Quote Link to comment Share on other sites More sharing options...
wallaby Posted December 27, 2010 Share Posted December 27, 2010 For setting warm lash specs on a cold engine, Crane says add .002 for iron head and subtract.006 for aluminum. Here is the page: http://www.cranecams.com/pdf-tech-tips/mech-lift.pdf Quote Link to comment Share on other sites More sharing options...
71monteme Posted December 31, 2010 Author Share Posted December 31, 2010 thanks for the info page. will be working on the motor this weekend. i'll post how close those figures are on that page. thanh Quote Link to comment Share on other sites More sharing options...
71monteme Posted January 3, 2011 Author Share Posted January 3, 2011 well, did the hot lash on the motor at 30. let engine cooled overnight and remeasure lash. it was at 25-26 so the crane cam page was pretty close. i run aluminum comp roller rockers for reference, hope some one can use this info. thanh Quote Link to comment Share on other sites More sharing options...
wallaby Posted January 4, 2011 Share Posted January 4, 2011 If you're using a computer program to evaluate your combo, don't forget to subtract that .030 from your valve lift specs. Quote Link to comment Share on other sites More sharing options...
680HPStroker Posted January 6, 2011 Share Posted January 6, 2011 I always set the lash on a solid roller cam to the spec on the cam card your cam manufacture supplies with your new cam. There is no one fits all setting. There is a reason why the manufacture gives you the spec they do. Quote Link to comment Share on other sites More sharing options...
