SS Haze Posted July 2, 2011 Share Posted July 2, 2011 I might have to take the tail housing off my 70 - TH400. Tail shaft seal refuses to come out. Is there a gasket between the housing and the tranny? If so, I can't seem to find one. Thanks, Mike Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted July 2, 2011 Share Posted July 2, 2011 It may be an o ring type but I would have to check the book for sure. But that tail shaft seal should come out of there, may have to use a some force or seal puller but should come out. Quote Link to comment Share on other sites More sharing options...
SS Haze Posted July 2, 2011 Author Share Posted July 2, 2011 Gonna try again tomorrow. As you say, it should come out. I used some a seal puller, but that sucker is not cooperating. Mike Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted July 2, 2011 Share Posted July 2, 2011 use a chisel to bend up the edge of the seal that sits against the tailhousing, work your way around to bend up a much as you can, then grab a hold of it with some vise-grips, clamp it as close as you can to the tailshaft housing then just push (using the housing as a pivot point) the vise-grips down and it should start to pull the seal out Quote Link to comment Share on other sites More sharing options...
wallaby Posted July 2, 2011 Share Posted July 2, 2011 I've seen cases where adhesive was used on assembly...makes it really tough to remove later! Sometimes a seal puller simply rips through the seal like a can opener, instead of trying to actually pull it out. I have a medium-sized crescent wrench that works perfect for this job and I use it just as I would use a "real" seal puller. The added width of the jaws help prevent it from ripping through the seal. You just have to select the proper size wrench so it will fit in the gap between the output shaft and the seal. Quote Link to comment Share on other sites More sharing options...
SS Haze Posted July 2, 2011 Author Share Posted July 2, 2011 What a stubborn piece of seal that was. Got out, replaced, and test driven. Now to see if that fixes the leak. Thanks for all the advice. Mike Quote Link to comment Share on other sites More sharing options...
