Big block headers....?
look at the bottom of this forom it talks about headers i put these on my ss454 they are almost perfect -----------------------------------------------------------------------------andreas is always great when he recommends something
I can recommend the Dynomax BB headers part no. 86110. Ceramic coated for less than $230...
They needed minor dinging on the passenger side to clear the lower A-arm mount
Jegs and Summit have them
<IMG SRC=\"http://www.first...971 SS454 PAGE
LARRY
[This message has been edited by 71ss454 (edited 05-11-2003).]
The Dynomax are indeed tha best bang for the buck...
71 Monte 454 HO 5- Speed "FULMNTE"
86 Monte LS "The Gray Mouse" FOR SALE!
01 Camaro V6
Andreas' Monte Carlo Site
Member NMCOA, FGMCC (Event Coordinator)
I think there is some information on headers in the engine forum archive. You can get to it from the message board main page. It in the bottom left corner. Monte
70 Monte Carlo. 355, 10.4 to 1, AFR 210's, 1 3/4" super comps, solid roller 585/597 260/266 @.050 on 112LSA, Edelbrock tunnel ram w/2 600 hp's, 4,000 stall, 4.11. 3800 lbs. 4000lbs with me in it, 12.4 @ 111 mph, 2.000 60' time, launching at 1/2 throttle for 60' to keep from spinning the tires. With that mph it should be between 11.8 and 12.2 once I get it to hook up. New Times coming for the new rear end set up and 200 shot of nitrous.
The Catalogue on www.dynomax.com lists 86110 for Camaro, Chevelle, El Camino, Full Size Big Block cars.
They did fit my Monte with some dinging of one tube on the passenger side to clear the lower A-Arm mount...
