467 in monte runnin
ScottNM
Thank you. I took a good friend for a 40 mile cruise and he was quite impressed with the power. I put new ball joints, bb springs and kyb shocks in front. I must say this thing rides very nice down I40. I am looking forward to getting the posi diff in there soon. It is from a 70mc. I have poly bushings to install on the diff unit and it has a sway bar. I hope it does not stiffin up the ride to much. I have my gauges in except RPM guage. I have been going back in forth between a retro column mounted unit or a removing the clock and putting oem type there.
If it helps I vote in dash for the tach. I have one car , my 67 firebird, with the tach on the column and if I could find an in dash unit that I like I would change it. I don't know if mine would be considered retro since I did it that way in 1978 and just left it lol. I am gathering parts right now for the 70 Monte to do the in dash conversion. David
I agree with you. The only reason I even debate it is because of line of sight. I like this thing as stock looking as possible. They ahve one on "ground up" for chevelle and looks like a fit. I need to call them and ask if the rpm gauge are identical for MC. 160 I believe.
