dimitri Posted February 19, 2012 Share Posted February 19, 2012 i need to know which direction to go ? i have a 2 core radiator and need to know if it will cool properly should i get a electric pusher fan or get a new 3 or 4 core radiator i know ive asked this question before but cant remember what i was told Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted February 19, 2012 Share Posted February 19, 2012 call alumatech they will take good care of you Quote Link to comment Share on other sites More sharing options...
dimitri Posted March 21, 2012 Author Share Posted March 21, 2012 just to update this i am running with the 2 core radiator and cut the big block shroud down one lip and there is a 1 inch gap between it and the flex a lite fan i am running at 150 to 160 degrees with no t stat Quote Link to comment Share on other sites More sharing options...
502ci Posted March 21, 2012 Share Posted March 21, 2012 and cut the big block shroud down one lip and there is a 1 inch gap between it and the flex a lite fan i am running at 150 to 160 degrees with no t stat Are you saying you cut it back so the fan does not actually extend slightly into the shroud? If so it was supposed to be like that so it pulls the air way better, otherwise it is not creating a "vacuum" of air in the shroud through the radiator. Also not running a T stat is no good, your car is running too cool right now. Quote Link to comment Share on other sites More sharing options...
