Guest Posted November 20, 2006 Share Posted November 20, 2006 The build sheet from my 71 has a scheduled build date of 02 09-03. Could someone please tell me what that translates to? Thanks Link to comment Share on other sites More sharing options...
savvarock Posted November 20, 2006 Share Posted November 20, 2006 Looks like your monte should have been built February 9th 2003. Good question. I would like to know also. Link to comment Share on other sites More sharing options...
Rob Peters Posted November 20, 2006 Share Posted November 20, 2006 The build sheet from my 71 has a scheduled build date of 02 09-03. Could someone please tell me what that translates to? Thanks I am not positive but judging by how they did some things and since you don't have a hyphen between the 02 and the 09 I suspect the build date may have been September 3rd and maybe the 02 indicates the shift on that date. Again, I am guessing on this. Look on the drivers door. They originally placed a blue sticker with the build date and vin number on the drivers door near the latch. Rob Link to comment Share on other sites More sharing options...
gprimm Posted November 21, 2006 Share Posted November 21, 2006 Are these numbers in the upper left hand corner of the build sheet? The first number, 02, is the sequence build number of the car, that is, it was the 2nd car built (started) on Sept. 3rd. George Primm Link to comment Share on other sites More sharing options...
Guest Posted November 21, 2006 Share Posted November 21, 2006 George you are correct, upper left hand corner, box #10, SCHED. NO. DATE. I would assume that it was Sept. 1970? By Sept. 1971 they should have been into 1972 model year production. Thanks Link to comment Share on other sites More sharing options...
Sam (Bones) Posted November 21, 2006 Share Posted November 21, 2006 or was it sept '69 ? my '70 build sheet says 05 01-05 I know it was built first week of january 1970 Link to comment Share on other sites More sharing options...
NateZ Posted November 22, 2006 Share Posted November 22, 2006 Are these numbers in the upper left hand corner of the build sheet? The first number, 02, is the sequence build number of the car, that is, it was the 2nd car built (started) on Sept. 3rd. George Primm Agree with George. At which plant was your car built? The only plant I know of that did not follow the format George mentioned above, was Arlington. Also, what does your trim tag (cowl tag) show for a build date? It should coincide with the date shown on the build sheet, within a week or so. As an example, my Baltimore-built Monte's build sheet shows Feb. 25, 1970 as the build date, and the cowl tag shows "03A" or first week of March, 1970. Link to comment Share on other sites More sharing options...
Guest Posted November 28, 2006 Share Posted November 28, 2006 It was built at the Kansas City Plant. The car is currently buried in a storage unit, so I don't have access the cowl tag right now. But thanks for the info. Link to comment Share on other sites More sharing options...
