72 LS5 Posted April 18, 2012 Share Posted April 18, 2012 Can anybody recommend a leak free carb to manifold gasket for a Holley? I always get that nasty gas stain oozing from under the carb. Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 18, 2012 Share Posted April 18, 2012 I had that problem with the holly that came on my car. I checked out the base of the carb and one corner was bent leaking gas and sucking air. Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted April 18, 2012 Share Posted April 18, 2012 sounds like you may have a warped base Mike...have you tried to double them up? Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted April 18, 2012 Author Share Posted April 18, 2012 I thought to double them up. Â This 25 year old swap meet Holley 850 sure looked laser-straight when I put it on....after a few beers....in the dark....with one eye open... Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted April 19, 2012 Share Posted April 19, 2012 I thought to double them up. Â This 25 year old swap meet Holley 850 sure looked laser-straight when I put it on....after a few beers....in the dark....with one eye open... Â that's when everything looks its best.... Quote Link to comment Share on other sites More sharing options...
72 LS5 Posted April 19, 2012 Author Share Posted April 19, 2012 But seriously, I saw Mr Gasket has a thicker rubber "vibration isolator gasket" that may be worth a try. My base plate may not be laser-straight, but judging from all the leakage I see at car shows, I'm not the only one oozing fluids . Quote Link to comment Share on other sites More sharing options...
CrazyDavey Posted April 19, 2012 Share Posted April 19, 2012 But seriously, I saw Mr Gasket has a thicker rubber "vibration isolator gasket" that may be worth a try. My base plate may not be laser-straight, but judging from all the leakage I see at car shows, I'm not the only one oozing fluids . Â TMI !!!! Quote Link to comment Share on other sites More sharing options...
70mcarlo Posted April 19, 2012 Share Posted April 19, 2012 Quote Link to comment Share on other sites More sharing options...
Andy's Auto Posted April 20, 2012 Share Posted April 20, 2012 Mikey, I have a new AED 850 baseplate at the shop. Gimme a call. Quote Link to comment Share on other sites More sharing options...
Mike 57 Posted April 21, 2012 Share Posted April 21, 2012 I wonder if your leak is actually coming from the throttle shafts? The base gasket leakage would cause more vacuum idle issues than raw fuel. Quote Link to comment Share on other sites More sharing options...
