72-CLASSIC_RIDE Posted June 24, 2012 Share Posted June 24, 2012 I have been running my car (72 Monte) for the past 5 years without the A/C working. This year was determined to have that problem fixed and was. With the A/C on I understand there is a selenoid that attaches to the Card that when A/C is activated, the selenoid engages allowing throttle to maintain RPM. As it is now, when A/C is on, the load causes engine to loose RPM. I looked up the A/C schematic but getting lost as to the location wiring would attach to selenoid. I am guessing that wire connection would come from the same green wire that plugs into the Compressor Pump but can't determine this as fact as there doesn't seem to be a available wire. Pic identifies where I believe selenoid wire shoud come from where circled. Also, anyone have a pic(s) showing the selenoid at Carb I can study? Any help with this appreciated. Doug Quote Link to comment Share on other sites More sharing options...
Leghome Posted June 24, 2012 Share Posted June 24, 2012 I looked at a 72 yesterday and the wire going to the solenoid was yellow and ran along the inside of the drivers side valve cover from the firewall. I am getting ready to reinstall my AC for the trip to the Eastern Meet in GA. so I have been checking out every Monte Chevelle that has I come across. Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted June 25, 2012 Author Share Posted June 25, 2012 Appreciate the info Larry. Been looking at schematics but haven't been able to isolate wire origin to solenoid as yet. Not very well versed on reading these schematics and unsure how this solenoid is described in diagram(s). Closest I came is a Idle Switch location and wire is Pink. Looked at some pic's I have kept in my photo program and as I have never had this device on my car was unsure where/how the solenoid was mounted. I saw a few pic's that were clear enough to know where/how was mounted but couldn't pick out the wire running to solenoid. Still looking! Doug Quote Link to comment Share on other sites More sharing options...
1972mc Posted June 26, 2012 Share Posted June 26, 2012 just looked at mine- I had cut wire and then re-installed my A/C. The splice was buried in the main wire harness but my schematic says it's tan 20 g. Carefully cut or peel back the tape on main harness just below and to the left of the wiper motor. I converted to a Holley carb some time ago so needed the correct solenoid and bracket. Ordered it from Holley. Don't have p/n but they will know exactly what you'll need. Good luck. Carl Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted June 26, 2012 Author Share Posted June 26, 2012 Thank you much Carl, I'll fish it out and go from there. Have a Eddy 4 bbl Carb & will find compatible solenoid & bracket if there is one. I saw a Tan wire in schematic that I kept focusing on. Will revisit and see if it was the one I needed to find. May still be different as I can't remember what ga. wire it was. Thanks again Carl. I'm sure my wire is buried in that Harness. Have a GREAT day, Doug Quote Link to comment Share on other sites More sharing options...
Leghome Posted June 26, 2012 Share Posted June 26, 2012 That yellow wire I saw was spliced so it could have been tan near the firewall. Now I know what color to look for on my 72. Quote Link to comment Share on other sites More sharing options...
